RE: Các trang web về Suzuki 4WD
Standard Vehicle names from around the world (see what they call a vit elsewhere!)
http://www.zukiworld.com/forum/index.php?topic=8792.0
IFS - Independant front suspension
SAS- Solid axle swap
BL - Body Lift
1" = 2.54cm/25.4mm
G16A - 1.6L carby motor SOHC 8 Valve
G16B - 1.6L EFI motor DOHC 16Valve
SUZUKI WHEEL STUD PATTERN 5 ON 5.5" M12x1.25 STUD 108MM CENTRE HOLE
The Ackerman Steering Principle
http://www.rctek.com/handling/ackerman_steering_principle.html
--- The Ackerman Steering Principle defines the geometry that is applied to all vehicles (two or four wheel drive) to enable the correct turning angle of the steering wheels to be generated when negotiating a corner or a curve ---
Gear ratio/Crawl ratio/Speed/RPM/Tyre size Calculator
http://www.izook.com/gearcalc.htm
Unit Converter (HP ----> KW etc.)
http://www.mr2ownersclub.com/converter.htm
V8 VITARA by OVERKILL ENGINEERING!
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=50874
GENERAL VITARA:
EFI Vitara Diagnostic Trouble Codes
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=48874&sid=f4416ea74aa7c757df06f2a4019373f4
General Engine Info
http://www.twistedandes.com/cont/articulo.php?id=48
Vitara Servicing Specifications (ignition, valve clearances etc)
http://zookpower.ca/tech.html
Vitara 5 door wagon as Play Thing
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=45606
5 Door Vit Project! (sweet, with lots of tech also!)
http://www.zukiworld.com/forum/index.php?topic=8808.0
General Vitara pics
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=36930
Lifted Grand Vitara
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=41865
What to look for when buying '88-'98 Vitara (CJ's the man!)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=55981
Things to look out for when buying a Vitara
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=48417
Looking to buy a Vitara? (general mods tech)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=30752
SWB Vitara Info
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=3388
Vitara BUDGET lift info
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=33780
V6 Vitara Tech:
Calmini 3"lift,RR2"bodylift and 225 76 16 tires
www.angelfire.com/trek/4x4gravel/go.html
Old Man Emu Suspension Spec
www.drivetrain.com/EMU/emusuzuki/emusuzuki.html
Some archives from Jays V6 Vitara Site,
V6Vitara.com archives.rar, available p2p on Emule
Some archives fro the SupaZuki Site
k9rdj.com archives.rar, available p2p on Emule
ZukiWorld USA Members Rides' (look here if you are searching for inspiration)
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1114707300
Operation: ROCKSTAR (project Vitara in the USA)
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1104768202
ENGINE:
Vitara EFI and forced Induction
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=35497
Weber Carby on G13 tech (similar for G16 also)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=28919
EFI Vitara diagnostic
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=54840
D.I.Y engine rebuild (G16 motor) updated!
http://www.zukiworld.com/forum/index.php?topic=59.0
Pics of Zaggy's engine (this is the dude who did the DIY engine rebuild)
http://www.zukiworld.com/forum/index.php?topic=176.0
1.6L Turbo Engine carnage pics (some tech)
http://www.zukiworld.com/forum/index.php?topic=7.0
1.3L, 1.6L Engine Tech (over-bore, machining, etc)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=49231
Vitara G16B Head Gasket and Torque values
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=14362
Lubrication Guide for Vitara 1.6 16V efi
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=46866
Water leak
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=47498
Vitara EFI and forced induction
1.3L head on 1.6 block (engine tech)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=26129
G16B idle surge on back-off
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=48844
Grand Vitara Snorkel
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=34299
some cam tech for G16
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=33452
Cheap Motor Mount Fix
http://www.zukiworld.com/forum/index.php?topic=8962.0
1600 8V ECM tech
http://www.zukiworld.com/forum/index.php?topic=8948.0
Removing Crank Bolt on G16
http://www.zukiworld.com/forum/index.php?topic=8963.0
TBI (throttle body injection) spacer tech
EXHAUST:
Header/Extractor Design
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=35746
GEARBOX/TRANSFER/CLUTCH:
Removing Vitara gear box and clutch tech
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=45612
Vitara 4WD activation
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=39716
Slip yoke eliminator:
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=42488
Dual Transfer case build and tech
http://bbs.zuwharrie.com/content/topic,13663.0.html
Kicker 3 (OTT industries company manufactured dual transfer set up)
http://www.ottindustries.com/kicker3.htm
DIFFERENTIALS:
Stan's Toyota CV swap KIT
http://www.zukiworld.com/forum/index.php?topic=9229.0
Hilux Diffs in Vitara (using Hilux IFS too)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=34011
Vitara Rear diff 5.83 ratio options
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=50295
Vitara Dana 44 Hybrid Axles
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=646
Front Diff drop brackets
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1119451178
Welding Vitara Diff
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=4895
Front wheel bearing replacement
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=31092
Common Gear Ratios for: SWB and LWB Vitara (1.6L)
http://bbs.zuwharrie.com/content/topic,15579.0.html
Common Gear Ratios for: 2.0L Vitara, Grand Vitara, and Grand Vitara XL-7
http://bbs.zuwharrie.com/content/topic,18763.0.html
LOCKERS
Vitara Front Locker by Trail Tough
http://www.zukiworld.com/forum/index.php?topic=9852.0
want to buy a lockright? (where from and Mi-Goreng tech)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=33318
Grand Vitara Rear Diff lockers
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=50314
SUSPENSION:
using Nissan 180SX coils in rear of vit (rear coil tech)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=54646
Vitara Rear Shocks and Front struts tech (cheap rear shocks)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=55812
Vitara SAS kits (by overkill)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=43631
CELIA & EUGENE BARRY's SAS Vitara (survivor chick pics)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=31617
Calmini Kit on Vitara
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=30327
Lifting a Grand Vitara
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=44709
Lifting a Grand Vitara (suspension tech)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=33301
Calmini Australian Dealers
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=43544
Calmini Suspension and Crawler gears
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=30145
Vitara Body and Suspension lift tech
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=30138
Tyres and Suspension (with coil spacer install write up)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=46893
Tyres and Suspension (with rear shock and Body Lift info)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=40398
General info on Tyres and Suspension Mods
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=38594
Lifting SWB Vitara
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=29854
how to change Vitara front coils
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=40455
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=39517
Vitara front Struts (OEM vs TOUGH DOG vs OME)
independant front suspension
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=48730
Front lower control arm replacement
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=42126
Vitara 5 door wheel base
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=39409
Vitara Drop Pitman arm
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=34900
Vitara rear suspension, rear upper drop bracket, and brakes
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=34844
Front strut spacers and rear upper drop bracket
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1110082830
How to make your own Coil Spacers (US version)
http://www.zukiworld.com/forum/index.php?topic=7930.0
Common spring rates for Suzuki modification (spring rate tech)
http://bbs.zuwharrie.com/content/topic,18699.0.html
Rear Upper Drop bracket specs (rear diff upper control arm)
http://bbs.zuwharrie.com/content/topic,18175.0.html
Coil Spacer tech (american)
http://bbs.zuwharrie.com/content/topic,16333.0.html
Coil spring rate calculator
http://therangerstation.com/tech_library/coilspringrate.htm
TYRES:
235/75R15 Tyre upgrade
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=44895
Tyre pressures for 235/75R15 on SWB vit
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=54014
235/75R15 and 30" Tyres
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=7527
A/T Tyres
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=46455
fitting 34" tyres on vit (+ trimming and gearing discussion)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=32076
31"s on a Vitara
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=1861
Big tyres VS. Small tyres
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=46388
WHEELS
how to find wheel off set (and wheel fitment)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=33597
Rims and Offsets (with link to measurements and calculations)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=61462&sid=683c7fbbf893454ad91e0d66f18e19e9
FUEL TANK:
Vitara fuel tank capacity
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=41793
SWB Fuel tank lift
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=48700
LWB Fuel tank lift
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1119671953
BODY and CHASSIS:
RUST, RUST and more RUST, how to DIY and like it! (part 1)
RUST, RUST and more RUST, how to DIY and like it! (part 2)
http://www.zukiworld.com/forum/index.php?topic=8945.0
Vitara Grill Info
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=55068
Pics of Vitara Guard Cutting (for 31"+ tyres)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=55976
Bodylift (sizes, detail etc)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=49288
Rear Crossmember replacement
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=32610
SWB rear storage ideas
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=41658
Rear drop down tail gate, and bonnet struts
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=41455
Exo cage costing and info
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=39784
Pic of Vit 6 point roll cage (comp style!)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=55376
Vitara Body Studs (are M10x1.25!)
http://www.outerlimits4x4.com/PHP_Modules/phpBB2/viewtopic.php?t=55208
Cutting Firewall to fit larger tyres
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1120388428
BL - Body Lift
1" = 2.54cm/25.4mm
GENERAL VITARA:
General Engine Info
General Vitara pics
Lifted Grand Vitara
SWB Vitara Info
V6 Vitara Tech:
ENGINE:
Water leak
1600 8V ECM tech
EXHAUST:
DIFFERENTIALS:
Welding Vitara Diff
LOCKERS
SUSPENSION:
Lifting SWB Vitara
TYRES:
A/T Tyres
31"s on a Vitara
WHEELS
FUEL TANK:
SWB Fuel tank lift
LWB Fuel tank lift
BODY and CHASSIS:
Vitara Grill Info
Em thấy bộ đèn nó đã quá, khỏang bao nhiêu xiền vậy bác?
http://www.arb.com.au/
Mấy bộ đèn IPF của ARB toàn 5-600$ cả bác ạ. Bác thử tham khảo các bộ đèn này xem nhé, tính năng cũng ngang ngửa với IPF mà giá chỉ bằng 1/3 này. http://www.narva.com.vn/products.asp?l=y&menu_id=ultima
http://4x4ph.com/forum/index.php?showforum=21
Cái trang này bên Philipine có khá nhiều thông tin về Vịt đời đầu như ở VN các bác ạ.
Re: RE: Các trang web về Suzuki 4WD
Không biết hỏi ở đâu, tiện vào đây hỏi các bác luôn là trước đây box Su có rất nhiều bài nhưng sao giờ chỉ còn có 1 trang vậy các bác?!
Thỉnh thoảng hay vào xem lại mấy bài về cảm nhận của các bác về xe APV... nhưng giờ thì không biết kiếm đâu?
