RE: Lexus LS400, xin các bác tư vấn dùm em.
Cám ơn BS nhiều lắm ạ! nhưng em vẫn cần một số thông tin thêm về em này
. Sợ nhất khoản ko có phụ tùng thay thế.
Thông tin tạm có:
2000 Lexus LS400 Specifications:
2000 Lexus LS400 Performance & Efficiency Standard Features View
3,969 cc 4 liters 8 V engine with 87.5 mm bore, 82.5 mm stroke, 10.5 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
- Premium unleaded fuel
- Fuel economy EPA highway (l/100km): 9.4
- Multi-point injection fuel system
- Main 85 liter premium unleaded fuel tank
- Power: SAE and 216 kW , 290 HP @ 6,000 rpm; 300 ft lb , 407 Nm @ 4,000 rpm
2000 Lexus LS400 Handling, Ride & Braking Standard Features
- ABS
- Brake assist system
- Four disc brakes including four ventilated discs
- Electronic traction control via engine management
- Immobilizer
- Fullsize alloy rim internal spare wheel
- Stability control
- Wishbone front and rear suspension with stabilizer bar independent with coil springs
2000 Lexus LS400 Exterior & Aerodynamics Standard Features
- Body side molding
- Front and rear toned bumpers
- Chrome/bright trim around side windows, on side of body and on bumpers
- Coefficient of drag: 0.28
- Day time running lights
- Driver and passenger power heated body color door mirrors with automatic and automatic operation
- External dimensions: overall length (mm): 4,996, overall width (mm): 1,829, overall height (mm): 1,435, wheelbase (mm): 2,850, front track (mm): 1,575, rear track (mm): 1,575 and curb to curb turning circle (mm): 10,607
- Front fog lights
- Complex surface lens halogen bulb headlights
- Heat reflective glass
- Luxury trim wood/woodgrain on gearknob
- Metallic two-tone paint , black two-tone paint , pearl two-tone paint
- Rear window
- Tinted glass on cabin, rear and side
- Weights: curb weight (kg) 1,764
- Windshield wipers with automatic intermittent wipe
2000 Lexus LS400 Interior Standard Features
- Air conditioning with climate control and rear outlet
- Diversity antenna
- Peripheral anti-theft protection
- Front and rear ashtray
- Manufacturer's own audio system
- Automatic drive indicator on dashboard
- Cargo capacity: all seats in place (liters): 394
- Front seats and rear seats cigar lighter
- Computer with average speed, average fuel consumption, instantaneous fuel consumption and range for remaining fuel
- Dashboard full console , floor full console with covered storage box , overhead partial console
- Cornering lights/curb illumination
- Delayed/fade courtesy lights
- Cruise control
- Front seats and rear seats cup holders
- Door ajar warning
- Door entry light
- Door pockets/bins for driver seat, passenger seat and rear seats
- External temperature
- Driver and passenger front airbag
- Bucket seat
- 3-point reel height adjustable front seat belts on driver seat and passenger seat with pre-tensioners
- Front seat center armrest
- Garage door opener
- Height adjustable two head restraints on front seats , height adjustable three head restraints on rear seats
- Headlight control with time delay switch-off and dusk sensor
- Illuminated entry system
- Internal dimensions: front headroom (mm): 988, rear headroom (mm): 937, front hip room (mm): 1,450, rear hip room (mm): 1,440, front leg room (mm): 1,110, rear leg room (mm): 937, front shoulder room (mm): 1,471, rear shoulder room (mm): 1,450 and interior volume (liters): 2,888
- Low fuel level warning
- Low washer fluid level warning
- Memorized adjustment on door mirror position and steering wheel position with four driver's seat positions
- Remote power locks includes trunk/hatch and includes power windows
- Vehicle speed proportional power steering
- Front and rear power windows with two one-touch
- Front and rear reading lights
- 3-point reel rear seat belts on driver side, passenger side and center side
- Rear seat center armrest
- Bench fixed three rear seats
- Automatic operation rear view mirror
- Remote fuel filler door release
- Electric remote trunk/hatch release
- Front seat back storage
- Leather seat upholstery
- Seatíng: five seats
- Frontco side airbag
- Sevien speakers
- Woỏ d steering wheel
- Tachometer
- Driver a nd passenger illuminated vanity mirror
- V chentilation system with recirculation setting and micro filter
(info from automotive.com)
Hình như con này đời 2000 là hết sản xuất rồi. Con này có vẻ hay hay
. Nhưng sao nó ghi đường trường cũng chỉ có 9.5l/100km àh.hic, nhưng cũng phải vì nó là xe mới, chứ xe cũ rồi chắc cũng hao xăng.
