Nikon D5100 đi bác Sinhviengià , còn dư bao nhiêu tiền thì mua lens
The D5100 digital-SLR camera primary specifications</h2> Type Single-lens reflex digital camera Lens mount Nikon F mount (with AF contacts) Effective pixels 16.2 million Image sensor 23.6 X 15.6 mm CMOS sensor mage size (pixels) [*]4,928 X 3,264 (L) [*]3,696 X 2,448 (M) [*]2,464 X 1,632 (S) [/list] File format 1) NEF(RAW), 2)JPEG, 3)NEF(RAW)+JPEG Media SD (Secure Digital) memory cards *1
SDHC, and SDXC memory cards Frame advance rate Up to 4 fps *2 ISO sensitivity ISO 100 – 6400 in steps of 1/3 EV. Can also be set to approx. 0.3, 0.7, 1, or 2 EV (ISO 25600 equivalent) above ISO 6400; auto ISO sensitivity control available Movie Frame size (pixels) and frame rate :
[*]1,920 X 1,080, 30 p/25 p/24 p,
high/normal [*]1,280 X 720, 30 p/25 p/24 p,
high/normal [*]640 X 424, 30 p/25 p,
high/normal [/list] A frame rate of 30 p (actual frame rate 29.97 fps) is available when NTSC is selected for video mode. 25 p is available when PAL is selected for video mode. Actual frame rate when 24 p is selected is 23.976 fps.
File format/Video compression:
MOV, H.264/MPEG-4 Advanced Video Coding
Audio recording device:
Built-in monaural or external stereo microphone; sensitivity adjustable Monitor 3-in., approx. 921k-dot (VGA), vari-angle low-temperature polysilicon TFT LCD with 170° viewing angle, approx. 100% frame coverage, and brightness adjustment Power source Battery : One rechargeable Li-ion EN-EL14 battery
AC adapter : EH-5b AC adapter; requires EP-5A power connector (available separately) Dimensions (approx.)
(W×H × D) 128 X 97 X 79 mm Weight (approx.) 510 g without battery, memory card, or body cap
560 g with battery and memory card but without body cap Major supplied accessories EN-EL14 rechargeable Li-ion battery, MH-24 battery charger, AN-DC3 strap, EG-CP14 audio/video cable, UC-E6 USB cable, DK-5 eyepiece cap, BS-1 accessory shoe cover, DK-20 rubber eyecup, BF-1B body cap, ViewNX 2 CD-ROM [*]*1Not applied to Multi Media Card [*]*2Manual focus, mode M or S, shutter speed 1/250 s or faster, and other settings at default values [/list] [*]Unless otherwise stated, all figures are for a camera with a fully-charged battery operating at an ambient temperature of 20° C (68° F). [/list]
