bác nào rành âm thanh chỉ giáo em với ạ.
em định lắp bộ này lên xe mit mirage được ko
http://www.ebay.com.au/itm/PIONEER-...760480?hash=item41958a90e0:g:bhAAAOSwymxVRwLR
Get more out of your music
Are your car's factory speakers sounding less than fresh? Pioneer built their A-Series speakers to be high-performance replacements for your old speakers designed from the ground up to bring back the life that your music's been missing. You'll be able to enjoy the clear vocals chunky guitar riffs powerful drums and distinct bass lines that have always been a part of your favorite tunes but have remained hidden behind sub-par speakers.The woofer will add depth and impact to your favorite tunes.
Built to make your music rock
Pioneer equipped the TS-A1605C component speaker system with multilayer 6" mica-matrix woofers that stay rigid when the volume's turned up keeping distortion to a minimum so your bass sounds
clean. Install the separate 3/4" tweeters in a good spot up high in your vehicle for better stereo imaging. The system also includes 2-way outboard crossovers a step up from the inline tweeter high-pass filters usually found in systems in this price range.
These speakers will sound great running off your factory stereo but they'll really shine when driven by an aftermarket receiver or an external amp. Don't drive another day listening to tired-sounding tunes when you can enjoy Pioneer sound quality with these speakers in your vehicle.
The TS-A1675S - Get more out of your music
Are your car's factory speakers sounding less than fresh? Pioneer built their A-Series speakers to be high-performance replacements for your old speakers, designed from the ground up to bring back the life that your music's been missing. You'll be able to enjoy the clear vocals, chunky guitar riffs, powerful drums, and distinct bass lines that have always been a part of your favorite tunes, but have remained hidden behind sub-par speakers.The multi-driver array on this speaker brings out all the midrange and high-frequency details.
Built to make your music pump
Pioneer equipped the TS-A1675S 6-1/2" speakers with multilayer mica-matrix woofers that stay rigid when the volume's turned up, keeping distortion to a minimum so your bass sounds clean. Each woofer gets paired up with a midrange speaker and a tweeter to add warmth and clarity to your driving soundtrack. These speakers will sound great running off your factory stereo, but they'll really shine when driven by an aftermarket receiver or an external amp. Don't drive another day listening to tired-sounding tunes, when you can enjoy Pioneer sound quality with these speakers in your vehicle.
Plays loud and clear
Many people never think to upgrade their car's audio system suffering with subpar sound when they listen to music. Pioneer's GM-A4604 4-channel amplifier will greatly improve the sound quality in your vehicle so you'll look forward to spending time on the road.
This punchy Pioneer amp will power your front and rear speakers with 40 watts RMS each which is a huge jump over the power supplied by your car radio. You'll hear more of the little details in your music even when you turn your system up to compete with the road noise.
Practical features
You can also put this versatile amp into 2-channel mode to send up to 120 watts RMS each to a couple of component speakers or subwoofers. Switchable 80 Hz high- and low-pass filters on the A channels help take the rumble away from full-range speakers or the sizzle away from a sub. The B channels sport variable high-and low-pass filters so you can better adjust the sound for critical front soundstaging or a finely-tuned bass. Speaker-level inputs allow you to add the GM-A4604 to a factory radio. This amp's performance features and reasonable price make it a great choice for almost any vehicle needing a sonic upgrade.
Hyper Connections and the new hyper-flex™ technology brings an end to the age old problem of stiff hard to work with cables, with our revolutionary Hyper-Tension™ power and ground cables it give the installers the balance of high flexibility whist still having enough stiffness to push thru firewalls and hard to reach places with ease.
Hyper Connections Pro series products are made from the highest quality TCCA, CCA & OFC materials and have been custom designed to give the best performance possible whilst still giving customers the best value for money possible.
Our RCA interconnects are designed and engineered using the latest BTSP (balance twisted shielded pairs)
technology, giving the some best possible low level signal reproduction available on the market today whilst blocking out the vast majority of interference from other signals in the automotive environment.
In each and every pro series kit, we offer our customers Mini ANL fusing (usually only found in higher end kits) colour coded speaker wire, split loom, oversized power and ground cables and other accessories not usually supplied in kits of this nature and all backed by our fully Australian based, owned and operated warranty and support team.
As a part of our ongoing commitment to the
environment and in alignment with our company Eco friendly policy each hyper Connections product is supplied with the most minimal amount of fully recyclable packaging, to maximise the value for money and minimise our impact on the enviroment.
Each Pro Series kit Contains:
2 x 5m BSTP RCA Interconnect
1 x 5m Transparent frosted power cable
1 x 1m Transparent frosted ground cable
1 x 14m Dual Colour Transparent frosted speaker cable ( 2 core)
1 x 5m Transparent frosted remote wire
1 x 1.8m black split loom
1 x Mini ANL fuse & Fuse holder
8 x black Cable ties
2 x nickel plated ring terminals & colour coded covers
6 x Nickel plated speaker terminals & colour coded covers
2 x Cable grommets
Product Highlights
Practical features
2 x Cable grommets
Product Highlights
- Series: A (Pioneer)
- Speaker Design: 2 Way Component
- Rms Power: 60
- Peak Power: 350
- Sensitivity Db: 90dB
- Impedance: 4 Ohm
- Mounting Depth (mm): 55
- Type: 2 x Tweeters + 2 x 6" Woofers + 2 Crossovers
- Speaker Design: 3 Way Coaxial
- Rms Power: 50
- Peak Power: 300
- Impedance: 4 Ohm
- Mounting Depth (mm): 46
- Type: 2 x 6.5" Speakers + Grills
- Number Of Channels: 4 - Channel
- Minimum Impedance Unbridged: 2 Ohm
- Minimum Impedance Bridged: 4 Ohm
- Bass/Gain Remote: Not Included
- Speaker Level Inputs: Yes
- Maximum Input Gauge Size: 8 Gauge
- Amplifier Class: AB
- Series: GM (Pioneer)
- Built In Crossover: Full (AP)
- Brand: Pioneer
- Combined Rms Power Output: 240
- Combined Peak Power Output: 480
- Preamp Outputs: 0
- THD: 0.05%
- S/N Ratio: 95dB
- Dimensions: 317 x 215 x 63 mm
- Rms Output @ 4 Ohms: 4 x 40
- Rms Output @ 2 Ohms: 4 x 60
- Rms Output Bridged @ 4 Ohms: 2 x 120
- Number Of Channels: 2 - Channel
- Brand: Pioneer
- Combined Rms Power Output: 180
- Combined Peak Power Output: 400
- Preamp Outputs: 0
- THD: 0.05%
- S/N Ratio: 95dB
- Dimensions: 241 x 177 x 63 mm
- Rms Output @ 4 Ohms: 2 x 60
- Rms Output @ 2 Ohms: 2 x 90
- Rms Output Bridged @ 4 Ohms: 1 x 180
- Brand: Pioneer
- Subwoofer Size: 12"
- Voice Coil: Single Voice Coil
- Impedance Per Voice Coil: 4 Ohm
- Rms: 350
- Peak: 1300
- Subwoofer Color: BLACK WITH RED TRIM
- Passive With Enclosure: YES
- Ported Enclosure: YES
- PORT TYPE : CUSTOM SIDE PORT
- Number Of Subwoofers: 1
- Dimensions: 508 x 328 x 379
- Colour: SILVER
- Channel : 2
- Series : Pro (Hyper Connections)
- Remote Wire : 5M
- Size : 8 AWG
- Colour: GREEN / SILVER
- Fuse Type : MINI ANL
- Fuse Size : 60 AMP
- Channel : 2
- Remote Wire : 5M
- Speaker Cable : 14M
