8.170
33.852
Crash recovery crews survey a C-17 on the runway of Bagram Airfield, Afghanistan, after it landed wheels up Jan. 30. The pilots forgot to lower the plane's landing gear as they approached the base.
8.170
33.852
C 17 chở thương binh
A Medical evacuation flight (Mississippi Air National Guard's 172nd Airlift Wing/791st Expeditionary Aeromedical Evacuation Squadron) from Balad Air Base, Iraq, to Ramstein Air Base, Germany, on February 25, 2007. US Air Force personnel gather patient information on a C-17 aeromedical evacuation mission from Balad Air Base, Iraq to Ramstein Air Base, Germany
Reactions: phatbinhduong
8.170
33.852
Maintenance and explosive ordnance disposal personnel from the 447th Air Expeditionary Group prepare to place explosive charges on the wings of a C-130 Hercules aircraft that are designed to divide the plane into smaller sections so it can be moved July 7 in Baghdad, Iraq. The C-130 made an emergency landing in a field north of the Baghdad International Airport shortly after take-off on June 27. (U.S. Air Force photo/Tech. Sgt. Jeffrey Allen)
387
grenade nói:
lính ngồi trong C17 đến Iraq
hay quá, đúng là anh cả của thế giới.
chiếc này mà đưa cho vn thì chất lính vô ko còn chổ mới thôi:D:D
hình của bác lựu đạn toàn hàng khủng thôi:):)
8.170
33.852
Senior Master Sgt. Pervis King from the 447th Air Expeditionary Group's explosive ordnance disposal team climbs through the top hatch of a C-130 Hercules aircraft before placing explosive charges around the wings of the plane July 7 in Baghdad, Iraq. The team is using a series of controlled detonations designed to divide the airplane into smaller pieces so it can be moved. The C-130 made an emergency landing in a field north of the Baghdad International Airport shortly after take-off on June 27. (U.S. Air Force photo/Tech. Sgt. Jeffrey Allen)
8.170
33.852
Iraqi freedom
An explosive ordnance disposal team from the 447th Air Expeditionary Group detonates explosives attached to the wings of a C-130 Hercules aircraft in Iraq July 7. The aircraft was disabled after it made an emergency landing last month, and the Airmen are using a series of controlled detonations to divide the aircraft into smaller pieces so it can be moved. (U.S. Air Force photo/Tech. Sgt. Jeffrey Allen)
8.170
33.852
MADA'IN REGION, Iraq – A CH-47 Chinook helicopter prepares to land in the desert region of the Mada'in, located outside of eastern Baghdad following "Operation Winged Lion II," June 26. The Iraqi-led air assault clearance operation was conducted to assess security in the region and deny enemy movement into the city.
