Status
Không mở trả lời sau này.
Mãi yêu El
25/3/09
3.815
43.430
Re:Giao lưu anh em PKL tại Sg
Sẳn đây bàn luận tí, khi e vào cua với vận tốc trên 100, xe nghiêng xuống bên này người e ngã sang bên kia để đè xe xuống thì cua rất  đã và ko lấn sang làn dg ngược chiều. Có ai chạy như e ko? có đúng kĩ thuật ko?  Dòng cruise nhé
P39
251
Chịu khó đọc nè,, có đủ cả
http://www.totalmotorcycl...chool-SectionFiveB.htm
Typical Cruiser Dimensions (2003 Honda VTX1800)
Rake 32.0 degrees
Trail 152.0mm (6.0 inches)
Wheelbase 67.5 inches
Therefore: With a rake of 32 degrees and a trail of 152mm (6 inches) this motorcycle will be better and more stable in a straight line than turning a tight corner. The long wheelbase of 67.5 inches also assists this motorcycle again in straight line performance but will hinder it in cornering. So this motorcycle has been properly designed for it's intended purpose (touring, cruising, and highway use).
Typical Sport Bike Dimensions (2003 Honda CBR600RR)
Rake 24.0 degrees
Trail 95.0mm (3.7 inches)
Wheelbase 54.7 inches
Therefore: With a rake of 24 degrees and a trail of 95mm (3.7 inches) this motorcycle will turn much quicker and sharper than the Cruiser, but will not be as good or as stable in a straight line. The short wheelbase of 54.7 inches also assists this motorcycle again in cornering but hinders straight line stability. So this motorcycle has been properly designed for it's intended purpose (going in and out of corners at high speeds and taking twisty roads)
Steering - Rake and Trail
[blockquote]What makes one motorcycle turn better than another one? What is heavy steering? What is rake and trail any ways?
Rake is the angle between the headset tube and a vertical line. Increasing the rake will move the front tire farther from the bike. Rake is measured in degrees, and is a frame specification. To visualize trail, draw an imaginary line along the path of the headset tube to the ground. Measure from this point to the center of the tire patch. This is trail, and is measured in inches.
[/blockquote] The amount of rake is significant in determining a motorcycle's handling characteristics. In general, more rake provides greater straight line stability, less rake makes the bike more responsive. Larger values of trail also create more straight line stability. This is why the forks on a sportbike are more vertical than those of a cruiser.
<span style=""color: #0000ff;""> Sau khi đọc khái niệm về steer, Rake và Angle.. thì đọc tiếp về balance ..</span>
http://www.tonyfoale.com/...es/Balance/BALANCE.htm
BALANCING ACT.
© Tony Foale 1986 -- 1997
Let's return to basics and look at the mechanisms of stability and steering, as they relate to single track vehicles (motorcycles in other words).
BALANCE.
As a single track vehicle, a motorcycle lacks inherent static balance, i.e. it falls over, if left to its own devices when stationary.
Once moving above a certain speed however even the most uncoordinated riders find that the machine seems to support itself. So it is obvious that there are two aspects of the balance process, the low speed case and that in the higher speed ranges. There have always been clever sods who can balance indefinitely on a stationary bike, but for most of us we need a minimum of forward motion before this is possible. However, at these low speeds it is necessary to move the handlebars from side to side to stay upright, and as all trials riders know, it is easier if we stand on the footrests instead of sitting down. Let's examine why. Fig.1 shows the rear and top views of a bike and rider. Now, if the combined centre of gravity (C.of G.) is vertically above the line joining the front and rear tyre contact patches, then balance is achieved, but this is an unstable situation, any small distubance such as a light breeze will be enough to start a topple over, i.e. the C.of G. moves sideways.
This can be prevented by either of two methods or a combination of both, one is to move the tyre contact patch line to under the new position of the C.of G. If the bike is stationary this can only be done to a limited extent by moving the bars, however once under way we can steer the bike to place the position of the tyre line wherever we need it, and this is why it is easier to balance when moving. The other way to maintain low speed balance is by moving the combined C.of G. of both the rider and machine to above the line joining the tyre contact patches. This is what trials riders are doing when moving their bodies from side to side whilst standing up. The high C.of G. of the rider has more effect on the toppling over moment and also gives more control over the position of the bike's C.of G. Thus to a great extent the process of low speed balance is dependent on the individual skill of the rider. In addition, some bike parameters can also affect the ease of remaining upright, the main ones being:
[*]1. A low C.of G height helps. [*]2. A large trail changes the position of the tyre line more for a given handlebar movement. [*]3. A small rake angle reduces the fall of the steering head when the bars are turned away from the straight ahead position, assisting with the balance process. The balance mechanism at higher speeds is more complex, but at least is largely automatic and independent of rider ability. To understand the action it is necessary to look at a few properties of gyroscopes, which is another way of describing spinning motorcycle wheels.
A spinning wheel has a very stable axis of rotation, i.e. a strong tendency to maintain its plane of rotation. In other words, while it can easily be moved laterally along the axis of spin, it resists tilting about any other axis, and more importantly, when it is tilted it automatically causes a strong twisting moment about an axis at 90 degrees to that of the original tilt. This twisting effect increases as the speed of the wheel rises, this is known as gyroscopic precession. When you have finished reading this, I expect you to go and remove the front wheel from your brother's mountain-bike, if you then obey the following intructions you will get a graphic practical demonstration of the strength of these precessional forces, which are so vital to the balance and steering of any bike. Firstly hold the wheel upright, as in fig.2, get your young brother (well he won't be out riding, will he?) to spin it so that the top of the wheel is moving away from you, as if it were the front wheel of a machine you were riding. If you then try to tilt the spindle to the LEFT (equivalent to banking your machine) you will find that the wheel _turns instantly and strongly to the LEFT, as if steered by an invisible hand. In other words, your attempt to tilt the wheel about its fore-and-aft axis has produced a torque swivelling it about its vertical axis. Now start again but this time turn the wheel to the LEFT about a vertical axis, just as sharply and strongly it will bank to the RIGHT. Try both these manoeuvres again, but do it at different wheel speeds and tilting speeds, you will see that the precessional forces depend strongly on these factors. Note particularly, the directions in which these forces operate as this is important for the automatic retention of balance. Let us now see how these forces keep the machine balanced and on a relatively straight path without assistance from the rider. Suppose the bike, whilst travelling along at a normal speed, starts to fall to the left under the action of some extraneous influence. As we have just seen, gyroscopic precession of the front wheel immediately turns it to the left. This sets the machine on a curved path (to the left), so creating a centrifugal force (to the right), which counters the lean and tends to restore the machine to the vertical, the precessional forces are thus reversed tending to restore the steering to the straight ahead position. In practice, that which we regard as riding in a straight line, is really a series of balance correcting wobbles, if we could look at the actual paths taken by the centre-lines of the wheels, we should see that the front wheel path continually crosses that of the rear. In the explanation above, I have only described the effects on the front wheel, precessional forces are at work on the rear also, but it is much harder to steer the rear wheel independently, as the whole bike must yaw, rather than just the wheel and forks, as on the front. Hence, only a small contribution is made to the auto-balance mechanism by the rear. We have now considered balance in a straight line, but as we lean when cornering, there must be other factors at work to maintain equilibrium under these conditions.
STEERING (CORNERING).
To analyse this, we can divide it into two phases;-
1. Initiating the turn,
2. Maintaining the turn.
Since the second phase is easier to analyse, let's look at it first. It is not feasible to steer a motorcycle through a corner in a substantially upright position, as in a car or side-car outfit, because the centrifugal force generated would cause it to fall outward. Hence we must bank the bike inward so that this tendency is counteracted by the machines weight tending to make it fall inward. See fig.3.
Equilibrium is achieved when the angle of lean is such as to balance the two opposing moments, the one due to centrifugal force acting outward, and the other to gravitational force acting downward (both acting through the C.of G.). The actual angle, which depends on the radius of the turn and the speed of the machine, is that at which the resultant of the two forces passes through a line joining the front and rear tyre contact patches. This is the steady-state roll axis. But how do we actually initiate the turn - do we lean or do we steer first? Let's see what happens with each method. If we turn the handle-bar in the direction in which we want to go, both centrifugal force and the front wheel precession would cause the bike to topple outward, and that leads to gravel rash. But if we momentarily try to turn the bar quickly in the opposite direction, (sometimes known as counter steering) then these two forces will combine to bank the machine to the correct side. Gravity will then augment the banking effect and this, in turn, will give rise to gyroscopic forces helping to steer the front wheel into the curve, whereupon the processes for maintaining balance as described above take over and keep the bike on our chosen path. This is all very well, I hear you say, but if this is the way to corner, how come we can steer a bike no-hands. Well, it certainly is possible to do so, but only with a lot more difficulty. Precise control and tight turns are difficult to accomplish without handle-bar manipulation. Just try it! Let's consider the no-hands situation. As we saw earlier, simply banking the bike steers the front wheel in the correct direction automatically, through precession. But how do we make the bike lean in the first place, what do we have to push against? There is nothing solid to push against and so the only way to apply bank (without the facility of steering), is to push against the machine with the inertia of our own body. This means in practice, that in order to lean the bike to the right, we must initially move our body to the left. So now we have two possible methods of initiating a turn, and it is interesting to note that in both of them (banking and reverse handle-bar torque) our physical effort is in the opposite sense to that which might be thought natural, but when learning we adapt quickly and the required action becomes subconsciously automatic. It is these reverse actions that require us to learn to ride in the first place, when learning most of us wobble about out of control until our brain latches on to the fact that counter-steering and counter-leaning is the way to do it. Once the brain has switched into reverse gear, it becomes instinctive and is usually with us for life, and we could return to riding after a long layoff with no need to relearn the art of balancing or steering. So which of these two possible methods of initiating a turn do we use in practice? We probably subconsciously combine both methods, and the pressure on the inner handgrip is partly forward (counter-steering) and partly downward (banking). Remember though, that the actual counter-steering movement is very small, since gyroscopic precession depends for its strength on the speed of movement not on the amount of movement. If you still don't believe that steering to the opposite side works, then next time you are out riding, try jerking the bars quickly to one side, and see what happens. Leave yourself plenty of road if your reactions are a bit on the slow side. Do this at about 40 mph., and don't blame me if you fall off. The relative proportions with which we combine the two methods depend partly on riding style but also on speed and machine characteristics. For example, a heavy machine with light wheels at low speeds demands a different technique from that applicable to a light weight machine with heavy wheels at high speeds, and hence the two machines will have a different feel. But humans adapt quickly and the correct technique soon becomes second nature. It may seem strange that in the above discussion no mention has been made of such important parameters as, steering geometry, wheel and tyre size, wheelbase, frame stiffness and so on. This is simply because, balance and the ability to start and maintain a turn can be achieved within a wide range of these parameters. That is not to say that these factors are unimportant. We shall now look a little more closely at one of the more important parameters that come under the heading of steering geometry, i.e. TRAIL. Consider first fig.4, which shows the basics of steering geometry.
TRAIL.
The primary function of this, it is often said, is to build in a certain amount of straight line stability, in addition to that obtained by precessional effects as described above. But trail also introduces other effects which are vital to the feel and handling of the motorcycle.
Fig.4 shows that both the front and rear wheels contact the road behind the point at which the steering axis meets intersects the ground, this gives rise to a self-centering effect on both wheels, rather like the castors on a super-market trolley. The measurement of this castor is called the trail. The mechanism by which trail produces a self-centering force can be understood by reference to fig.5,
If the wheel gets displaced from the straight ahead position, i.e. the wheel is at an angle to the direction of travel (slip angle is the technical term), a force at right angles to the tyre is generated. Since the contact patch is behind the steering axis (positive trail) then this force acts on a lever arm (approximately equal to the trail) to provide a correcting torque to the angled wheel. That is to say, if the steering is deflected by some cause e.g. uneven road surface, then positive trail automatically counter-acts the displacement and gives a measure of directional stability. However, as shown earlier, we cannot just consider any steering effect in isolation, gyroscopic forces must be considered also, suffice to say, at this stage, that in this case trail and precession work in harmony to keep us on the straight and narrow.
One may be forgiven for initially thinking, that because the rear wheel trail is much greater than that of the front, the rear wheel is the more important in this respect. The reverse is actually the case for several reasons. See fig.6.
Imagine that the contact patch of each wheel is, in turn, displaced sideways by the same amount (say ½ inch.). The front wheel will then be turned by approximately 7-10 degrees (depending on the value of trail) about the steering axis, this gives rise to a slip angle of the same amount and generates a sideways force that has only the relatively small inertia of the front wheel and forks to accelerate back to the straight-ahead position. But the slip angle of the displaced rear wheel will be much less (about ½ degree) and so the restoring force will be reduced accordingly, but this also has to act on the inertia of a major proportion of the machine and rider, hence the response is much slower than is the case with the front wheel. From this, we can see that increasing the trail as a means of increasing the restoring tendency on the wheels is subject to the law of diminishing returns. It must also be emphasized that the distubance to a machine's direction of travel, due to a sideways displacement of the tyre contact patch, is less from the rear wheel than the front because of the much smaller angle to the direction of travel that the displacement causes. To summerize, while the large trail of the rear wheel has a relatively small restoring effect, the effect of rear wheel displacement on directional stability is also small, and hence compensates. As mentioned before, trail has effects other than directional stability, let's look at a couple of the more important ones.
STEERING EFFECT.
If we lean a stationary machine to one side and then turn the handlebars, we find that the steering head rises and falls depending on the position of the steering. In motion, the effective weight of the bike and rider supported by the steering head, is reacted to the ground through the tyre contact patch. This force tends to turn the steering to the position where the steering head is lowest (i.e. the position of minimum potential energy). For a given amount of trail, this steering angle is affected by rake angle and wheel diameter, one reason why different size wheels feel different, if all else remains the same. As long as we have positive trail, as is normal, then this turning effect is into the corner. Thus the amount of front wheel trail affects the amount of steering torque that the rider must apply (hence the feel of the steering) to maintain the correct steering angle consistant with the radius of the turn and the bike's speed. Some bikes seem to need to be held down into a corner, whilst others need the opposite approach. This is also influenced heavily by tyre characteristics, but that will have to wait for another occasion.
<span style=""color: #ff0000;"">Túm lại NNX check lại 3 thông số Steer, Rake, Angle trên chiếc Vulcan của mình thì sẽ biết góc nghiêng tối đa an toàn trên xe khì vào cua. </span>
PS:[*] Trong các hình từ 1a ( phần balance Act) chử  C..G là viết tắt từ Trọng tâm . [*] gyroscopic: hệ thống bù trừ cho cân bằng động ( hồi chuyển ) .. giống như đuôi trực thăng nào cũng có vậy.
640
Anh tích phân tí ti:
1. Vật lý học: ôm cua là đưa trọng tâm xe về phía mặt đường hướng cua, vậy phải đè xe >>> trọng tâm thằng nài + trọng tâm xe phải rơi về hướng mặt đường >>> không có cách nào khác là mông + đùi + vai + xe phải đổ cùng phương (này, 4C đừng để anh phải vẽ mấy cái vectors rồi tổng hợp theo hình học lớp 11 nhé).
2. Tâm lý học: ngả xe bên này, vặn người bên kia là gỡ gạc tâm lý khi vào cua cho đỡ hốt thôi.
@Da đỏ: vào cua được thì ra cua được, cũng nhiều đau thương mới thành đấy cụ ợ! Em thì thế, không biết các cụ trình cao thì dư lào?
878
26
Vậy da đỏ phải kéo quân vào Nam
Cụ Chung  phải kéo quân ra Bắc
Em theo 1 vé xuyên Việt cùng Cụ
640
thinh43bc nói:
Xong là đấu đầu ở giữa cầu Hiền Lương!
Trong yên lặng lắng nghe câu hò luôn, nhẩy?
@P39: góc nghiêng tối đa thì phải xem vỏ (lốp xe) trước anh ạ. VD: Michelin PW1 là 52 độ nghiêng.
Mà 4C băn khoăn làm giề? Bản thân Trái Đất thân yêu (lòng chúng em biết bao tự hào, 1 quả cầu đẹp xinh lung linh giữa cái cck gì mà trời sao) nghiêng miẹ 23,5 độ rồi. 4C đi thẳng cũng đã là cua tự nhiên, thích nhé!! Nói cách khác, hỏi đã là tự giả nhời!
878
26
Cụ P39 có đi xuyên việt cùng bác Chung kg? nếu đi ngày mai AE mình đi tập bóc đầu , nhỏng đít ....ra Bắc biểu diễn hen....hia hia
640
thinh43bc nói:
Trước khi post cái này 45ph, anh có depart với 1 B-King ngay góc NKKN và Trần Quốc Toản (đường này Anh cực ghét). Mình ghen tị với nó luôn vì xe mình dek chạy được 2 bánh. Đau!
Mãi yêu El
25/3/09
3.815
43.430
Lại chử nữa
Túm lại là dc hay ko? e chạy vậy có ai chạy như e ko? mà e chạy vậy có thấy ai chạy lại em đâu ta:D
3.361
Mù Căng Chải
ChungTX nói:
Hên xui thôi
. Năm rồi ngoài này các cao thủ ăn đu đủ mà rơi rụng trong cua liên tục á
. Chả dám lạm bàn cái gì chỉ mong ráng đi cái xe làm thao mà ... ko té , dắt cái xe ko bị đổ là là mừng lắm dồi
p/s : trong đám hình trên nhiều chú đang ........ dắt xe trong cua đới :D:D:D.
2.425
6
@4C: buồn gái của Anh và 1 số bạn, Anh ngồi 1 mình làm tạm cái này
Thằng ngồi đối ẩm làm cái này (cũng của Anh)
Đời nhiều khi cũng đ.é0 cần phải là vui lắm!
[/quote]
Sao vậy Bạn! Giận cá nấu điện thoại à!!
Status
