576
30
Bác nào đang đi Chim Xanh chuẩn bị xiền để nâng cấp nhé. Mở ngoặc là dòng xe này hướng đến đối tượng là nữ, thành đat, tuy nhiên ở VN thì điều đó không quan trọng.
Nissan's "smart" air-conditioning system monitors air quality, mixing in outside air to constantly refresh the cabin. At 1,876 mm, the Sylphy’s cabin is the longest in its class. Its trunk is also the largest in its class at up to 504 liters (VDA) on two-wheel-drive models.
The electric powered driver’s seat is the first of its kind in the class, automatically adjusting seat and mirrors to the specific driver identified by the Intelligent Key.
The MR20DE engine furnishes 90% of maximum torque at 2,000 rpm, the most frequently used engine speed in daily driving, resulting in better fuel efficiency.
In combination with the MR20DE engine, Nissan's Xtronic continuously variable transmission (CVT) allows the quick response and smooth, powerful acceleration needed in daily driving along with fuel-efficiency equivalent to that of a 1.8-liter engine.
The all-aluminum HR15DE engine furnishes firm torque at medium and low speeds in a quieter and even more fuel-efficient package.
The chassis consists of a strut suspension system at the front of the car and an H-shaped torsion beam suspension system at the rear.
A preloading mechanism has been added to the valves in both the front and rear shock absorbers. This mechanism improves ride quality by reducing the damping force in the piston's high speed range, while maintaining the same level of force in the low speed range. The suspension system also incorporates internal rebound springs and ripple control shock absorbers and is optimally tuned, enabling the Sylphy to provide superb handling and stability combined with supple ride comfort.
The main options include a base 109-horsepower 1.5-litre engine that can be upgraded to a 133-horsepower 2.0-litre engine. Both powerplants have been tuned to deliver 90 percent of their peak torque from just 2,000 rpm, making progress a quiet and efficient affair. The only gearbox choice is Nissan's Xtronic CVT.
204
RE: 2006 Nissan Bluebird Sylphy
Cái này giá bên Nhật vào khỏang trên dưới 20k - không biết mang về mình có cạnh tranh được không??
Nghe nói giữa năm 2006 sẽ có xe nhập nguyên chiếc của Nissan và ưu tiên là loại sedan nhỏ có giá bán khỏang 35k tại vn
1.231
Vietnam
Post cũ nè bác .. có thêm vài hình :D
http://www.otosaigon.com/forum/tm.aspx?m=154050&mpage=1&key=chim%2cxanh&#154050
theo thông tin em có được thì con này sẽ xuất xưởng vào 2007
204
Nó bắt đầu bán ở Nhật từ tháng 12/2005 rồi bác ơi
148
49
sao bác lại bảo chiếc này dành cho phụ nữ thế??
chiếc này hay nhất là đạt mức cao về tiêu chuẩn khí thải và tiết kiệm nhiên liệu, ở bên em thì giảm được 1/2 tiền thuế
576
30
Trích đoạn: volang
Phụ nữ là đối tượng khách hàng tiềm năng bác ạ (chương trình marketing của Nissan nó định ra thế), còn xe này bất cứ ai có bằng lái đều có thể nhảy lên lái được, không phân biệt giới tính. Ở VN mà bán chiếc này giá phải chăng thì >90% tài xế sẽ là nam.
Nissan has launched it’s Nissan Bluebird Sylphy mid-sized luxury sedan in Japan, targetted at today’s executive woman, focusing on hospitality and care in mind.
148
49
uhm, bên em thì đi con này đa phần là đàn ông trung niên ít xèng, thích chạy sedan mà lại tiết kiệm, thanh niên không chạy vì dáng yếu, còn phụ nữ thì chạy mấy chiếc cụt đuôi như Honda Fit tiện hơn
